LG CU400 Bottom Half Assembly Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. LG CU400 Bottom Half Assembly  Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG CU400 Bottom Half Assembly  Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the button labeled 'PUSH' on the rear cover.
  2. LG CU400 Bottom Half Assembly  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG CU400 Bottom Half Assembly  Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG CU400 Bottom Half Assembly  Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the rear cover towards you.
  3. LG CU400 Bottom Half Assembly  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG CU400 Bottom Half Assembly  Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the battery, grasp the top front edge of the battery and pull the battery away from the phone.
    • When installing the new battery, have the metal contacts of the phone match up with the metal contacts of the battery.
  4. LG CU400 Bottom Half Assembly  Replacement, Bottom Half Assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG CU400 Bottom Half Assembly  Replacement, Bottom Half Assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the sim card by sliding the card out from under the retainer using either your fingers or a spudger.
  5. LG CU400 Bottom Half Assembly  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG CU400 Bottom Half Assembly  Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rubber covers in the highlighted locations using a metal spudger.
  6. LG CU400 Bottom Half Assembly  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG CU400 Bottom Half Assembly  Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six 3mm #000 flat Phillips head screws from the back of the phone using a Phillips #000 Screwdriver.
  7. LG CU400 Bottom Half Assembly  Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG CU400 Bottom Half Assembly  Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the headphone jack cover with your finger or metal spudger.
  8. LG CU400 Bottom Half Assembly  Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG CU400 Bottom Half Assembly  Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG CU400 Bottom Half Assembly  Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the metal spudger between the keypad assembly and back cover assembly and pry the two assemblies apart.
    • Pry gently as to not break the plastic clips that hold the two assemblies together.
    • Work your way around the perimeter of the phone with the metal spudger to separate the two assemblies.
  9. LG CU400 Bottom Half Assembly  Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG CU400 Bottom Half Assembly  Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once you have worked your way around the perimeter of the phone, you will have access to the components in the bottom half assembly.
Dan Hughes
crwdns2935283:010/03/16crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
IUPUI, Team 1-3, Harley Fall 2016 crwdns2935289:0IUPUI, Team 1-3, Harley Fall 2016crwdne2935289:0
IUPUI-HARLEY-F16S1G3
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 96
