This guide will teach you how to remove the back speaker, located directly underneath the back cover. Only minimal disassembly is required.
On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the two screw covers at the top of phone with tweezers.
Remove the six Phillips #000 (3mm) screws.
Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
Set the back cover with the speaker aside.
Use the plastic opening tool to pry the speaker cover off of the phone.
Use the plastic opening tool to pry the speaker out of the back cover.
Where can I buy the replacement parts?
