LG CF360 LCD Screen Replacement
  1. LG CF360 LCD Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG CF360 LCD Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
  2. LG CF360 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the battery.
  3. LG CF360 LCD Screen Replacement, Back Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG CF360 LCD Screen Replacement, Back Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two screw covers at the top of phone with tweezers.
  4. LG CF360 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six Phillips #000 (3mm) screws.
  5. LG CF360 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG CF360 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG CF360 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
    • The plastic side buttons fall out when you take the back cover off.
    • The back cover is connected to the speaker by red and black wires.
  6. LG CF360 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
    • Set the back cover with the speaker aside.
  7. LG CF360 LCD Screen Replacement, Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG CF360 LCD Screen Replacement, Motherboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool to gently lift the snapped-in motherboard from the front panel.
    • An orange ribbon from the LCD is connected to the underside of the motherboard, so do not force the motherboard from the rest of the phone yet.
  8. LG CF360 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the blue transparent tape from the connector.
  9. LG CF360 LCD Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the plastic opening tool, gently pry the LCD connector from the motherboard.
    • Set the motherboard aside.
  10. LG CF360 LCD Screen Replacement, Front Case: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take the front case and unscrew the four Phillips #000 (1mm) screws around the ribbon.
  11. LG CF360 LCD Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the orange ribbon from the number pad casing.
    • Set the number pad case to the side once it is detached from the ribbon.
  12. LG CF360 LCD Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two red sticker screw coverings at the top corners with tweezers.
  13. LG CF360 LCD Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four Phillips #000 (3mm) screws at the corners of the phone.
  14. LG CF360 LCD Screen Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG CF360 LCD Screen Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the red sliding backing from the front cover by inserting the plastic opening tool in between the two sections and going around the entire phone.
    • Set the red sliding backing and front cover to the side.
  15. LG CF360 LCD Screen Replacement, LCD Screen: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be very careful to not damage the green keypad board when using the plastic opening tool.
    • Use a plastic opening tool to carefully disconnect the silver L-shaped LCD screen ribbon.
  16. LG CF360 LCD Screen Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG CF360 LCD Screen Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • At this point, an orange ribbon is still connected to the white and black Zero Insertion Force (ZIF) connector on the keypad board. Be careful to not damage the ribbon.
    • Use tweezers to carefully pry up the black retainer on the connector.
  17. LG CF360 LCD Screen Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG CF360 LCD Screen Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the keypad board away from the phone casing using a plastic opening tool.
    • Slowly rotate the keypad board towards you to disconnect the second orange LCD screen ribbon and remove the board.
  18. LG CF360 LCD Screen Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you have never soldered before, or need a refresher, take a look at iFixit's soldering guide before starting this step.
    • Use a soldering iron and a solder wick to de-solder the 4 wires connected to the LCD screen.
    • The LCD screen can easily be removed at this point by lifting it from the phone casing.
Ricky Wai
crwdns2935283:010/15/13crwdne2935283:0
278 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-27, Amido Fall 2013 crwdns2935289:0Cal Poly, Team 4-27, Amido Fall 2013crwdne2935289:0
CPSU-AMIDO-F13S4G27
crwdns2935297:019crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,345
