Make sure your device is powered down before we start this procedure. The battery is one of the most important components to keep, and replace.
Turn the phone upside down so that the bottom of the back is facing you.
Slide the back down towards you and remove the back cover. You should hear a slight click as the cover comes off.
Gently remove the battery from the device.
