This guide helps you to replace the rear casing of a LG 440G Phone.
The rear casing of your phone plays a crucial role in protecting its internal components from damage and wear. Over time, it can become cracked, scratched, or loose, compromising the phone's durability and appearance. Replacing the rear casing can restore your phone’s structural integrity and give it a refreshed look.
Before you begin, make sure that your phone is powered off and it is unplugged from the charger.
            Turn the device off.
            To do so, press and hold the red button.
            Slide the rear cover downward
            Lift it off to access the battery
            Locate the small rounded recess to get access to the battery
            Gently, lift the battery
            Use a Phillips #00 screw driver to remove six screws.
            Run the plastic opening tool along the edge of the phone to release the casing cover.
            Lift the casing cover.
this would be most probably, the same guide to tear down the LG B470
