LG 32CS560 Power Supply Board Replacement
  1. LG 32CS560 Power Supply Board Replacement, Prepare your LG 32CS560 for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG 32CS560 Power Supply Board Replacement, Prepare your LG 32CS560 for disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay the TV face down on a soft surface
    • Remove the base of the TV by unscrewing the 4 base screws.
    • There is no base on the picture, the position of the base is marked whit the red box.
  2. LG 32CS560 Power Supply Board Replacement, Disassemble the LG32CS560: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG 32CS560 Power Supply Board Replacement, Disassemble the LG32CS560: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 15 Phillips head screws on the back of the TV.
    • Carefully remove the black plastic back panel of the TV to expose the electronics inside
  3. LG 32CS560 Power Supply Board Replacement, Disconnect & Remove the Bad Power Supply Board: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG 32CS560 Power Supply Board Replacement, Disconnect & Remove the Bad Power Supply Board: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG 32CS560 Power Supply Board Replacement, Disconnect & Remove the Bad Power Supply Board: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully disconnect the three wire bundles attached to the power supply.
    • Remove the four screws holding the power supply in place.
    • Now you can lift out the Power Supply Board.
    • If the black cylindrical component marked with yellow seems to have expanded or is leaking liquid or goo, then the power supply board is definitely bad.
crwdns2935229:025crwdne2935229:0
Coyt Barringer
crwdns2935283:010/11/14crwdne2935283:0
719 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-3, Donnelly Fall 2014 crwdns2935289:0USF Tampa, Team 1-3, Donnelly Fall 2014crwdne2935289:0
USFT-DONNELLY-F14S1G3
preciso duma destas power bord como fazer para ter
brun mendes - crwdns2934203:0crwdne2934203:0
You should discharge the 'black cylindrical component' before attempting this. That component is a capacitor which can store excess electrical charge.
Danny - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 57
crwdns2936753:030crwdne2936753:0 195
crwdns2942667:0crwdne2942667:0 46,706
