crwdns2959928:0crwdne2959928:0 ↓This repair guide will instruct the user on the proper technique for removing and replacing a broken keypad for a LG 1010 Cell Phone.
Turn off the cell phone and place face down on a flat surface.
While sliding the gray tab up, lift battery up and away from the cell phone.
While holding cell phone firmly in one hand, unscrew and remove the antenna with the other hand.
Pull the antenna housing (black tube) towards bottom of phone and remove.
Unscrew the four screws on the back case using a T6 Torx Screwdriver.
Pull the back cover straight off the phone using your thumb and forefinger.
Pry off circuit board with a flathead screwdriver.
Install new keypad and reassemble following these instructions in reverse order.
