LCD Screen Replacement
crwdns2869540:0crwdne2869540:0: 1.2천
3
32
94
1,208
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:045crwdne2931287:0
In this guide, you will be taught how to successfully replace the LCD screen on your camera.
    1. LCD Screen  Replacement, Battery Door: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
    2. LCD Screen  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
    3. LCD Screen  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
    4. LCD Screen  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LCD Screen  Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
      • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
    5. LCD Screen  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
    6. LCD Screen  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LCD Screen  Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LCD Screen  Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the plastic opening tool to pry the back and front casings of the camera apart.
      • Once pried apart use your hands to pull off the back plate of the camera.
      • You will need to apply a little bit of force to remove the back plate.
    7. LCD Screen  Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LCD Screen  Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LCD Screen  Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
    1. LCD Screen  Replacement, LCD Screen: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LCD Screen  Replacement, LCD Screen: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LCD Screen  Replacement, LCD Screen: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently pull the tab out of the motherboard and then the LCD screen should easily be removed.
Colton Lancsarics
crwdns2935283:002/10/16crwdne2935283:0
731 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-2, Sullivan Spring 2016 crwdns2935289:0USF Tampa, Team 3-2, Sullivan Spring 2016crwdne2935289:0
USFT-SULLIVAN-S16S3G2
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 94
crwdns2959996:0crwdne2959996:0 1,208
