LCD LG 37LF65 Capacitor replacement
  1. LCD LG 37LF65 Capacitor replacement, Open the case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off and unplug your device before starting this repair.
    • Open the case carefully while loosing the marked srews.
  2. LCD LG 37LF65 Capacitor replacement, Replace the capacitors: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check the power-board. If there are any blown-up capacitors, you should replace them.
    • For removing the capacitors, remove the board, take a soldering bolt and heat the solder points at the back of the board.
    • Insert the replacement capacitors and solder it. Check the poles!
  3. LCD LG 37LF65 Capacitor replacement, Testing capacitors: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you are not sure about the condition of the capacitors you can prove it with a good measuring device after the expansion.
Not all capacitors are need in any case. To reassemble your device, follow these instructions in reverse order.
crwdns2935229:010crwdne2935229:0
eugl18
crwdns2935283:001/18/13crwdne2935283:0
582 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 14,241
