Kyvol Cybovac L20 Brush Roller Motor Replacement
  1. Kyvol Cybovac L20 Brush Roller Motor Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin with the device laying on a flat surface with the power button facing up.
  2. Kyvol Cybovac L20 Brush Roller Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kyvol Cybovac L20 Brush Roller Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove both of the side brushes.
  3. Kyvol Cybovac L20 Brush Roller Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove two 1 mm screws that secure the panel.
    • Remove the battery panel.
  4. Kyvol Cybovac L20 Brush Roller Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kyvol Cybovac L20 Brush Roller Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slightly lift the battery out of the compartment.
    • Disconnect the battery connector.
    • Completely remove the battery.
  5. Kyvol Cybovac L20 Brush Roller Motor Replacement, Brush Roller Motor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the dust bin from the underside of the unit.
  6. Kyvol Cybovac L20 Brush Roller Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kyvol Cybovac L20 Brush Roller Motor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press in on the two clips holding the brush roller housing in place and remove the brush roller cover.
  7. Kyvol Cybovac L20 Brush Roller Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the brush roller.
  8. Kyvol Cybovac L20 Brush Roller Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight 12 mm Phillips screws from the underside of the unit.
  9. Kyvol Cybovac L20 Brush Roller Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kyvol Cybovac L20 Brush Roller Motor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kyvol Cybovac L20 Brush Roller Motor Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slightly lift the bottom of the unit from the top housing, with care not to pull or damage the connections between the top case and motherboard.
    • Disconnect the three motherboard connections that connect the top case and motherboard.
  10. Kyvol Cybovac L20 Brush Roller Motor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 5.8 mm Phillips screws holding dustpan sensor board in place.
    • Move the sensor to the side.
  11. Kyvol Cybovac L20 Brush Roller Motor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kyvol Cybovac L20 Brush Roller Motor Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 8 mm Phillips screws that secure the motor housing in place.
  12. Kyvol Cybovac L20 Brush Roller Motor Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kyvol Cybovac L20 Brush Roller Motor Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 7.4 mm Phillips screws from the belt assembly housing cover.
    • Remove the cover.
  13. Kyvol Cybovac L20 Brush Roller Motor Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slip off the belt and pulley from the inside of the motor housing.
  14. Kyvol Cybovac L20 Brush Roller Motor Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kyvol Cybovac L20 Brush Roller Motor Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 4.5 mm Phillips screws that secure the motor to the pully assembly housing.
    • Separate the motor from the housing.
  15. Kyvol Cybovac L20 Brush Roller Motor Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip the white motor motherboard connect and pull it directly up and out of its port.
    • Remove the motor.
Brad
crwdns2935283:004/01/24crwdne2935283:0
397 crwdns2915208:0crwdne2915208:0
IUPUI, Team 1-1, Harley Spring 2024 crwdns2935289:0IUPUI, Team 1-1, Harley Spring 2024crwdne2935289:0
IUPUI-HARLEY-S24S1G1
crwdns2942667:0crwdne2942667:0 86
