Kyocera Oystr Screen Replacement
  1. Kyocera Oystr Screen Replacement, Removing the battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kyocera Oystr Screen Replacement, Removing the battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kyocera Oystr Screen Replacement, Removing the battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure the phone is turned off before disassembly.
    • Lift the bottom of the phone's back cover upwards, revealing the phone's battery housing.
    • Remove the battery from the casing. This is simply a precaution.
    • Turn the phone over, so that the front side is facing you. Open the device in preparation for the next step.
  2. Kyocera Oystr Screen Replacement, Removing screws from screen: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kyocera Oystr Screen Replacement, Removing screws from screen: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kyocera Oystr Screen Replacement, Removing screws from screen: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel the Virgin Mobile sticker off of the phone's screen to reveal two screws beneath it.
    • Use the Tri-Wing Y0 screwdriver to remove the two screws from the screen.
  3. Kyocera Oystr Screen Replacement, Exposing internal components: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kyocera Oystr Screen Replacement, Exposing internal components: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kyocera Oystr Screen Replacement, Exposing internal components: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the plastic cover of the phone screen upwards with a plastic opening tool.
    • Remove the two screws from the metal cover.
  4. Kyocera Oystr Screen Replacement, Removing metal cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the metal cover by lifting up and away from the device.
  5. Kyocera Oystr Screen Replacement, Screen removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kyocera Oystr Screen Replacement, Screen removal: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kyocera Oystr Screen Replacement, Screen removal: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool to pry the phone's speakers up and away from the device. These speakers will dangle by the wires attached to the board.
    • Use your fingernail to detach the ribbon connecting the board to the screen.
    • Remove the damaged screen from the device.
  6. Kyocera Oystr Screen Replacement, Completing the repair: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Follow these steps in reverse order to replace Kyocera Oystr’s screen.
David
crwdns2935283:010/04/11crwdne2935283:0
24 crwdns2915208:0crwdne2915208:0
UW Stout, Team 5-7, Zhou Fall 2011 crwdns2935289:0UW Stout, Team 5-7, Zhou Fall 2011crwdne2935289:0
UWSTOUT-ZHOU-F11S5G7
My screen goes blank for days, then shows. maybe for minutes of seconds. Do I need to replace the screen, or is there a control I can try to bring back the display? The phone is charged and rings. Yours is a wonderful website. Thank you.
Martha Carnahan mpc@netsync.net
Martha Carnahan - crwdns2934203:0crwdne2934203:0
My screen goes blank for days, then appears, but only for minutes or seconds before it goes blank again. Do I need to replace the screen, or do you know if there a command which would solve the problem? The phone is charged and rings.
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 2,298
