Removing the rear casing is simple and easy with the right tools and a little effort. This is also the initial process to access the phone's internal circuitry.
Wedge the opening device into the side crease of the phone.
Slide the opening device downward to dis-join the rear casing from the front casing. Continue around all edges.
Remove the back casing from the front casing. Force may be necessary.
