Kyocera Opal S14 Display Panel Replacement
  1. Kyocera Opal S14 Display Panel Replacement, Display Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the phone and power off the device.
    • Remove the SIM and SD cards.
  2. Kyocera Opal S14 Display Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kyocera Opal S14 Display Panel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the phone face-up with the display facing you.
    • Use a Phillips #00 to remove the four screws.
  3. Kyocera Opal S14 Display Panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kyocera Opal S14 Display Panel Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Starting at the corner, use the iFixit prying tool and gently insert it between the edge of the screen and the frame.
    • Apply gentle pressure and slowly pry the screen away.
    • Work your way around the edge of the device in a circular motion.
    • Make sure the screen is lifting evenly from all sides.
  4. Kyocera Opal S14 Display Panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kyocera Opal S14 Display Panel Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After working your way around the screen with the prying tool, gently lift the display panel from the frame.
    • As you lift the screen, you'll start to expose the bottom parts of the phone, be careful not to pull the screen away too quickly, as it is still connected to the device via cables.
After successfully replacing the display, you'll need to reassemble the device by reversing the steps taken during disassembly. By doing this, you can easily reassemble your Kyocera Opal S14 and complete the display panel replacement.
Kimberlyn
crwdns2935283:010/14/11crwdne2935283:0
31 crwdns2915208:0crwdne2915208:0
James Madison, Team 1-49, Allen Fall 2011 crwdns2935289:0James Madison, Team 1-49, Allen Fall 2011crwdne2935289:0
JMU-ALLEN-F11S1G49
crwdns2942667:0crwdne2942667:0 1,106
