Kyocera Hydro Vibe Trim Replacement
  1. Kyocera Hydro Vibe Trim Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure that the device is turned off before beginning.
    • Look for a small indentation on the bottom of the phone.
    • Insert the plastic opening tool into the indentation and lift off the back casing.
  2. Kyocera Hydro Vibe Trim Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kyocera Hydro Vibe Trim Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kyocera Hydro Vibe Trim Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The large white component is the battery. Look for a small indentation under the arrow that says "LIFT."
    • Place the plastic opening tool in the indentation and lift the battery out of the socket.
  3. Kyocera Hydro Vibe Trim Replacement, Trim: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the screws holding the trim which are the four side screws on each corner.
    • Remove each screw with a Phillips screw driver #J00. The screws are 5mm Phillips.
  4. Kyocera Hydro Vibe Trim Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kyocera Hydro Vibe Trim Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the clasps holding the trim in place.
    • You will need to insert the metal spudger through the bottom of the trim and slowly push upwards to release the clasps.
  5. Kyocera Hydro Vibe Trim Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The trim is flimsy.
    • This is what the trim will look like once removed.
Phillip Newman
crwdns2935283:001/31/16crwdne2935283:0
142 crwdns2915208:0crwdne2915208:0
University of Kentucky Louisville, Team 1-5, Matravers Spring 2016 crwdns2935289:0University of Kentucky Louisville, Team 1-5, Matravers Spring 2016crwdne2935289:0
LOUISVILLE-MATRAVERS-S16S1G5
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 766
