Kyocera Event Rear Assembly Replacement
  1. Kyocera Event Rear Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kyocera Event Rear Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kyocera Event Rear Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the small notch on the bottom right side of the phone.
    • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
    • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
  2. Kyocera Event Rear Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • The plastic prying tool can be used to help remove the battery.
  3. Kyocera Event Rear Assembly Replacement, Locate the SIM card: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The SIM card slot can be seen in the middle left of the photograph.
  4. Kyocera Event Rear Assembly Replacement, Open slot and remove card: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kyocera Event Rear Assembly Replacement, Open slot and remove card: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The SD card slot can be opened and closed, as depicted by the tool.
    • The SD card itself slides into and out of the metal cover.
    • The gold tipped tines are what read the SD card along its bottom.
  5. Kyocera Event Rear Assembly Replacement, Remove the screws.: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kyocera Event Rear Assembly Replacement, Remove the screws.: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove seven of the 4.9mm tri-head screws. Keep them in a secure location.
  6. Kyocera Event Rear Assembly Replacement, Remove the back assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kyocera Event Rear Assembly Replacement, Remove the back assembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kyocera Event Rear Assembly Replacement, Remove the back assembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the back assembly away from the body on all four sides of the phone.
    • Start prying at the top and work around.
    • Remove the buttons for the volume and power-this will allow for easier disassembly.
    • The back assembly is firmly attached to the body of the phone so removing it will require some force.
Philip
crwdns2935283:002/13/15crwdne2935283:0
7 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 875
