Kyocera Event MicroSD Card Replacement
  1. Kyocera Event MicroSD Card Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kyocera Event MicroSD Card Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kyocera Event MicroSD Card Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the small notch on the bottom right side of the phone.
    • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
    • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
  2. Kyocera Event MicroSD Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • The plastic prying tool can be used to help remove the battery.
  3. Kyocera Event MicroSD Card Replacement, Locate the SIM card: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The SIM card slot can be seen in the middle left of the photograph.
  4. Kyocera Event MicroSD Card Replacement, Open slot and remove card: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kyocera Event MicroSD Card Replacement, Open slot and remove card: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The SD card slot can be opened and closed, as depicted by the tool.
    • The SD card itself slides into and out of the metal cover.
    • The gold tipped tines are what read the SD card along its bottom.
graysonmensah
crwdns2935283:002/13/15crwdne2935283:0
22 crwdns2915208:0crwdne2915208:0
That's the micro SD slot. That's not for a SIM card.
Carl Jr - crwdns2934203:0crwdne2934203:0
What if there's no metal cover?
Michael ansley - crwdns2934203:0crwdne2934203:0
That's for the sd card not the sim card
gasparesparza9 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,150
