Kyocera Event Battery Replacement
  1. Kyocera Event Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kyocera Event Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kyocera Event Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the small notch on the bottom right side of the phone.
    • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
    • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
  2. Kyocera Event Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • The plastic prying tool can be used to help remove the battery.
Jen Michaels
crwdns2935283:008/07/13crwdne2935283:0
22 crwdns2915208:0crwdne2915208:0
Ohio State, Team 1-1, Michaels Fall 2013 crwdns2935289:0Ohio State, Team 1-1, Michaels Fall 2013crwdne2935289:0
OSU-MICHAELS-F13S1G1
crwdns2942667:0crwdne2942667:0 4,340
