Kurio Xtreme Camera Replacement
  1. Kurio Xtreme Camera Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
  2. Kurio Xtreme Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kurio Xtreme Camera Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
    • There are two screws on each side of the device (four total).
  3. Kurio Xtreme Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kurio Xtreme Camera Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kurio Xtreme Camera Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
    • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
    • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
    • Carefully lift the back panel off of the rest of the device.
  4. Kurio Xtreme Camera Replacement, Camera: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the flat-topped connector that connects the cameras to the motherboard by using the plastic opening tool to pry up on each side.
  5. Kurio Xtreme Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kurio Xtreme Camera Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kurio Xtreme Camera Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the smaller, front facing camera by lifting up on the attached ribbon cable.
    • Remove the larger, rear facing camera by lifting up on the attached ribbon cable.
Mallory Myers
crwdns2935283:009/22/15crwdne2935283:0
1,190 crwdns2915208:0crwdne2915208:0
Baylor, Team 6-10, Williams Fall 2015 crwdns2935289:0Baylor, Team 6-10, Williams Fall 2015crwdne2935289:0
BU-WILLIAMS-F15S6G10
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 254
