Kurio Xtreme Camera Replacement
crwdns2869540:0crwdne2869540:0: 611
2
21
95
611
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2955944:0crwdne2955944:0: 5 - 10 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
If one or both of the cameras in your Kurio Xtreme are broken, follow this guide to replace them. The front and back cameras are connected, so you will be replacing both of them, even if only one is broken.
    1. Kurio Xtreme Camera Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
    2. Kurio Xtreme Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kurio Xtreme Camera Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
      • There are two screws on each side of the device (four total).
    3. Kurio Xtreme Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kurio Xtreme Camera Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kurio Xtreme Camera Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
      • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
      • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
      • Carefully lift the back panel off of the rest of the device.
    1. Kurio Xtreme Camera Replacement, Camera: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the flat-topped connector that connects the cameras to the motherboard by using the plastic opening tool to pry up on each side.
    2. Kurio Xtreme Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kurio Xtreme Camera Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kurio Xtreme Camera Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the smaller, front facing camera by lifting up on the attached ribbon cable.
      • Remove the larger, rear facing camera by lifting up on the attached ribbon cable.
Mallory Myers
crwdns2935283:009/22/15crwdne2935283:0
1,190 crwdns2915208:0crwdne2915208:0
Baylor, Team 6-10, Williams Fall 2015 crwdns2935289:0Baylor, Team 6-10, Williams Fall 2015crwdne2935289:0
BU-WILLIAMS-F15S6G10
crwdns2935297:084crwdne2935297:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 95
crwdns2959996:0crwdne2959996:0 611
