This guide will show you how to replace your Kurio's battery.
Make sure to open the back cover easily using the plastic opening tool.
Remove back cover by prying away from the device.
The easiest place to remove the cover is from the bottom and top, then try to open it from the right and left sides.
To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver.
After you remove your four screws use your plastic opening tool to help you open the plastic cover of your device.
Use the plastic opening tool to remove the battery from its place.
Remove the two wires using soldering tool to detach your bad battery from the device .
do you know where to buy a replacement battery ?
Any idea where I can purchase a replacement battery?
