Kurio Touch 4S Battery Replacement
  1. Kurio Touch 4S Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kurio Touch 4S Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kurio Touch 4S Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove back cover by prying away from the device.
    • The easiest place to remove the cover is from the bottom and top, then try to open it from the right and left sides.
    • Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
  3. Kurio Touch 4S Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kurio Touch 4S Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kurio Touch 4S Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver.
  4. Kurio Touch 4S Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After you remove your four screws use your plastic opening tool to help you open the plastic cover of your device.
  5. Kurio Touch 4S Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to remove the battery from its place.
    • The battery is glued into the device. So try removing it gently.
  6. Kurio Touch 4S Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two wires using soldering tool to detach your bad battery from the device .
    • Gently remove the wires one by one. Do not damage the head that is glued into the motherboard.
    • For more information on how to solder and desolder the wire Click here
Khalid AlTamimi
crwdns2935283:001/21/15crwdne2935283:0
275 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 6-5, Brown Winter 2015 crwdns2935289:0USF Tampa, Team 6-5, Brown Winter 2015crwdne2935289:0
USFT-BROWN-W15S6G5
do you know where to buy a replacement battery ?
Phil Bowring - crwdns2934203:0crwdne2934203:0
Any idea where I can purchase a replacement battery?
Brooke Lonsdale - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 1,729
