Kurio 7 Back Panel Replacement
crwdns2869540:0crwdne2869540:0: 3.2천
5
22
81
3,194
crwdns2959984:0crwdne2959984:0: 2
crwdns2959974:02crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 2
crwdns2959982:02crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:07crwdne2931287:0
If the back panel of your Kurio 7 is broken, this is an easy process to replace it. This also serves as a guide to opening the device for other repairs and replacements.
    1. Kurio 7 Back Panel Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kurio 7 Back Panel Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kurio 7 Back Panel Replacement, Back Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Begin by removing the rubber cover from the Kurio 7.
    2. Kurio 7 Back Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kurio 7 Back Panel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four 30 mm Phillips #00 screws from the outer case.
    3. Kurio 7 Back Panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kurio 7 Back Panel Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert the plastic opening tool in the gap between the front cover and the back cover of the device.
      • Slide the plastic opening tool around the edge of the device. Gently pry apart the tabs that hold the front cover and the back cover together.
      • Be careful not to break off the tabs that hold the front cover and the back cover together.
    4. Kurio 7 Back Panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kurio 7 Back Panel Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once all of the tabs are removed, the back cover should come off easily.
      • Gently remove the back cover. There are wires inside that may get caught on the cover while removing it. These wires are soldered to their components and are difficult to reattach.
Replace with a new back panel. To reassemble your device, follow these instructions in reverse order.
Eric Rice
crwdns2935283:004/14/14crwdne2935283:0
913 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-36, Maness Spring 2014 crwdns2935289:0Cal Poly, Team 12-36, Maness Spring 2014crwdne2935289:0
CPSU-MANESS-S14S12G36
crwdns2935297:084crwdne2935297:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 81
crwdns2959996:0crwdne2959996:0 3,194
