Krups F203 Coffee Grinder Trigger Assembly Replacement
  1. Krups F203 Coffee Grinder Trigger Assembly Replacement, Base Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Krups F203 Coffee Grinder Trigger Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Krups F203 Coffee Grinder Trigger Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Krups F203 Coffee Grinder Trigger Assembly Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Krups F203 Coffee Grinder Trigger Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Krups F203 Coffee Grinder Trigger Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
  4. Krups F203 Coffee Grinder Trigger Assembly Replacement, Detach Trigger Button from Base Plate: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The trigger button is held in with light tension clips. Gently pry them back to release.
  5. Krups F203 Coffee Grinder Trigger Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Krups F203 Coffee Grinder Trigger Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the white trigger.
  6. Krups F203 Coffee Grinder Trigger Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the contact points between the trigger button and the red wire and also where the plug attaches to the trigger button
    • Be sure to reference the how to solder video posted to the device page
Ian Hancock
crwdns2935283:010/22/14crwdne2935283:0
432 crwdns2915208:0crwdne2915208:0
Baylor, Team 4-2, Williams Fall 2014 crwdns2935289:0Baylor, Team 4-2, Williams Fall 2014crwdne2935289:0
BU-WILLIAMS-F14S4G2
crwdns2942667:0crwdne2942667:0 5,757
