Krups F203 Coffee Grinder Plug/Cord Replacement
  1. Krups F203 Coffee Grinder Plug/Cord Replacement, Base Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Krups F203 Coffee Grinder Plug/Cord Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Krups F203 Coffee Grinder Plug/Cord Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Krups F203 Coffee Grinder Plug/Cord Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Krups F203 Coffee Grinder Plug/Cord Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Krups F203 Coffee Grinder Plug/Cord Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
  4. Krups F203 Coffee Grinder Plug/Cord Replacement, Detach Trigger Button from Base Plate: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Krups F203 Coffee Grinder Plug/Cord Replacement, Detach Trigger Button from Base Plate: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The trigger button is held in with light tension clips. Gently pry them back to release.
  5. Krups F203 Coffee Grinder Plug/Cord Replacement, Remove the wire from two contact points: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the soldering iron to remove the existing solder.
    • Be sure to reference the how to solder video posted on the device page.
Ian Hancock
crwdns2935283:010/22/14crwdne2935283:0
432 crwdns2915208:0crwdne2915208:0
Baylor, Team 4-2, Williams Fall 2014 crwdns2935289:0Baylor, Team 4-2, Williams Fall 2014crwdne2935289:0
BU-WILLIAMS-F14S4G2
Thank you for posting this guide. Had to break the plastic "fingers" to remove the base.
Krups must have a special tool for this purpose.
Greg - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,451
