Krups F203 Coffee Grinder Base Plate Replacement
  1. Krups F203 Coffee Grinder Base Plate Replacement, Base Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Krups F203 Coffee Grinder Base Plate Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Krups F203 Coffee Grinder Base Plate Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Krups F203 Coffee Grinder Base Plate Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Krups F203 Coffee Grinder Base Plate Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Krups F203 Coffee Grinder Base Plate Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
crwdns2935229:09crwdne2935229:0
Brian Wolfskill
crwdns2935283:010/23/14crwdne2935283:0
432 crwdns2915208:0crwdne2915208:0
Baylor, Team 4-2, Williams Fall 2014 crwdns2935289:0Baylor, Team 4-2, Williams Fall 2014crwdne2935289:0
BU-WILLIAMS-F14S4G2
crwdns2947412:011crwdne2947412:0
Thanks! I was able to repair my broken cord.
wdswaim - crwdns2934203:0crwdne2934203:0
I'mworking on it as we write .
jerry - crwdns2934203:0crwdne2934203:0
Does anyone have a video tutorial explaining how the heck one removes the base?? I bought a spudger and it still doesn't help. It is awfully hard to loosen up.. I kept trying and trying but I stopped cause I'm concerned I might break the clips and the outside which the plastic is starting to stretch.. the clips are starting to lose their shape as well and worried I might break the spudger... Thanks
NeonAera - crwdns2934203:0crwdne2934203:0
I am having the same experience as NeonAera posted. I could clear 2 of the 4 clips, but not the others and getting the same issue of distorting the outside wall of the base , if I continue to try and pry the clips with the spudger. Thanks
Steve Ferrill - crwdns2934203:0crwdne2934203:0
We had a jammed . I disassembled according to the guide, scraped out the rust I found, lubricated with WD40 and reassembled. Went from not moving to working great. I broke all 4 tabs (guess I lack patience…) but gorilla taped it back together and it's totally solid.
Wade Brainerd - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 74
crwdns2942667:0crwdne2942667:0 12,183
