Krups CafeExpress FMA110 Disassembly
  1. Krups CafeExpress FMA110 Disassembly, Krups CafeExpress FMA110 Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Krups CafeExpress FMA110 Disassembly, Krups CafeExpress FMA110 Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #1 screwdriver, remove the four 13.8 mm screws on the bottom of the device.
    • Remove the metal plate.
  2. Krups CafeExpress FMA110 Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #1 screwdriver, remove the two 16.7 mm screws to release the power cable.
  3. Krups CafeExpress FMA110 Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Krups CafeExpress FMA110 Disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinch the clamps around the thinner part of the silicon tubing and slide them towards the corner of the tube.
  4. Krups CafeExpress FMA110 Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull the silicon tubing off of the metal tube.
  5. Krups CafeExpress FMA110 Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Krups CafeExpress FMA110 Disassembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinch the clamps around the thicker part of the silicon tubing and slide them towards the corner of the tube.
  6. Krups CafeExpress FMA110 Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the silicon tubing from the upper reservoir.
  7. Krups CafeExpress FMA110 Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #1 screwdriver, remove the three 13.8 mm screws towards the back of the base.
  8. Krups CafeExpress FMA110 Disassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the base of the device from the upper reservoir.
  9. Krups CafeExpress FMA110 Disassembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the switch out from the inside, releasing it from the plastic base.
  10. Krups CafeExpress FMA110 Disassembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the white ring from the switch and squeeze it to slide it through the opening in the base.
  11. Krups CafeExpress FMA110 Disassembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the rest of the switch back through the hole in the base.
  12. Krups CafeExpress FMA110 Disassembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Krups CafeExpress FMA110 Disassembly: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #1 screwdriver, remove the three 15.8 mm screws to release the inner components from the plastic base.
  13. Krups CafeExpress FMA110 Disassembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Krups CafeExpress FMA110 Disassembly: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #1 screwdriver, remove the two 11.5 mm screws on either side of the horizontal metal bracket.
  14. Krups CafeExpress FMA110 Disassembly: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the horizontal bracket to separate the heating element and wires from the hot plate.
  15. Krups CafeExpress FMA110 Disassembly: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the wire connectors from the thermal switch.
  16. Krups CafeExpress FMA110 Disassembly: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #1 screwdriver, remove the two 7.6 mm screws and remove the thermal switch.
  17. Krups CafeExpress FMA110 Disassembly: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Krups CafeExpress FMA110 Disassembly: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #1 screwdriver, remove the two 9.9 mm screws from the hot plate.
    • Separate the hot plate from its frame.
  18. Krups CafeExpress FMA110 Disassembly: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Krups CafeExpress FMA110 Disassembly: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the heating element reaches a certain temperature, the thermal switch shuts it off to prevent it from overheating.
Sam Sugerman
crwdns2935283:009/16/21crwdne2935283:0
327 crwdns2915208:0crwdne2915208:0
Tufts University School of Engineering, Team 1-8, Bell Fall 2021 crwdns2935289:0Tufts University School of Engineering, Team 1-8, Bell Fall 2021crwdne2935289:0
TUFTS-BELL-F21S1G8
crwdns2942667:0crwdne2942667:0 345
