Krups 963 Power Switch Replacement
  1. Krups 963 Power Switch Replacement, Removing Bottom Screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the device is unplugged before continuing.
    • Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
  2. Krups 963 Power Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single black Phillips size 0 10mm length screw on the back of the machine.
  3. Krups 963 Power Switch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom cover from the machine and slide it down the power cord.
  4. Krups 963 Power Switch Replacement, Power Switch: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your hands or a pair of needle nose pliers to remove the wire attached to the switch.
  5. Krups 963 Power Switch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip either in the inside or outside of the switch with the needle nose pliers or your hand, and pull to remove the switch.
Wyatt Hall
crwdns2935283:010/13/14crwdne2935283:0
842 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-25, Maness Fall 2014 crwdns2935289:0Cal Poly, Team 6-25, Maness Fall 2014crwdne2935289:0
CPSU-MANESS-F14S6G25
crwdns2917034:0crwdne2917034:0
Wyatt, thank you for the instructions. I need to replace the power switch on my Krups 963 coffee maker, but I can't find the part anywhere. Do you know where to order one from? Thanks, --Susan
susangellert - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 3,029
