Krups 963 Power Cord Replacement
crwdns2869540:0crwdne2869540:0: 1558
3
17
80
1,558
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: 5 - 10 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
No prior knowledge needed! Be sure to unplug the device before beginning this guide to avoid electrical shock and damage to yourself and the device.
    1. Krups 963 Power Cord Replacement, Removing Bottom Screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Make sure the device is unplugged before continuing.
      • Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
    2. Krups 963 Power Cord Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the single black Phillips size 0 10mm length screw on the back of the machine.
    3. Krups 963 Power Cord Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the bottom cover from the machine and slide it down the power cord.
    1. Krups 963 Power Cord Replacement, Power Cord: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Krups 963 Power Cord Replacement, Power Cord: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the PH2 (or similar) screw driver to remove the two 12mm screws holding the clear restraining brace.
      • Remove the restraining brace from the machine base.
    2. Krups 963 Power Cord Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a 2.0 flat head (or similar) screw driver to loosen the screw holding the power cord in.
Wyatt Hall
crwdns2935283:010/13/14crwdne2935283:0
866 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-25, Maness Fall 2014 crwdns2935289:0Cal Poly, Team 6-25, Maness Fall 2014crwdne2935289:0
CPSU-MANESS-F14S6G25
crwdns2935297:084crwdne2935297:0
crwdns2936753:030crwdne2936753:0 80
crwdns2959996:0crwdne2959996:0 1,558
