Korg nanoKONTROL2 Disassembly
  1. Korg nanoKONTROL2 Disassembly, Korg nanoKONTROL2 Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Korg nanoKONTROL2 Disassembly, Korg nanoKONTROL2 Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Korg nanoKONTROL2 Disassembly, Korg nanoKONTROL2 Disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Start by unplugging, then remove all the faders and knobs, by lifting them up gently.
  2. Korg nanoKONTROL2 Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Korg nanoKONTROL2 Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 8 screws on the bottom. Ensure that you have the right screwdriver bit, and that you go slowly and use enough force to turn the screw without stripping it.
    • (Serial numbers and personal info removed from picture)
  3. Korg nanoKONTROL2 Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Korg nanoKONTROL2 Disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After opening back lid, remove 14 screws from inside.
  4. Korg nanoKONTROL2 Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Korg nanoKONTROL2 Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Korg nanoKONTROL2 Disassembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You can now remove the main circuit board, lifting out the left side first. (as the mini-USB port may hold the right side in.)
    • The rubber buttons can now easily come out.
  5. Korg nanoKONTROL2 Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Features: (first picture)
    • 8 faders
    • 8 potentiometers
    • 8 x Solo, Mute, Record buttons
    • 5 + 4 transport buttons
    • 2 track buttons
  6. Korg nanoKONTROL2 Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Korg nanoKONTROL2 Disassembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Chips
    • Labelled with: 2210CFP24V H8S/2210C TH30140 1325
    • ROSON Crystal oscillator, labelled with 24.000F20 HO
    • LW051A 58A04 P256 Texas Instruments Analog multiplexer
    • Mini-usb port
    • Power indicator LED
jzohsuh
crwdns2935283:012/31/18crwdne2935283:0
160 crwdns2915208:0crwdne2915208:0
crwdns2947412:08crwdne2947412:0
Hi do you think it’s possible to replace the mini usb port on this, with a usb c connector bought online? I actually have a Korg Nanokey 2 but I think it’s the same setup.
Lemo - crwdns2934203:0crwdne2934203:0
Technically yes, but it won’t be easy as the pins are probably in different locations. There are only 4 pins on a USB micro B connector (not in order: Ground, 5V, D+, D-) and there are 24 on a USB C connector (12 different x2). If you have a way of connecting the right pins up then you can use a Dremel or another tool to make the connector fit through the hole if needed.
jzohsuh -
Yeah maybe I can solder it via some wires if it doesn’t fit directly. Actually I have zero experience in soldering, but I can get the stuff online, and then bring it to a shop to solder it for me I think. How about this, do you think it’s okay? https://www.aliexpress.com/item/10050014...
Lemo -
Also do you think that connector on this page is configured correctly as “host” if I buy the female port? Or I might need a resistor to change the mode similar to what he’s doing on this video? https://www.youtube.com/watch?v=V-vFtiDY...
Lemo -
Yes, that aliexpress link could work, provided you make enough space for it. For the resistor, I think it is likely that you'll have to change the mode, but you'll need to check once you've got the part.
I realise this is quite a delayed reply, sorry!
jzohsuh -
One of my faders is working funny ¿Will it be posible to fix?
Joaquin - crwdns2934203:0crwdne2934203:0
Maybe you can try to blow dry air into the fader. On the Novation Launch Control XL, the buggy faders may be serviced just by a dust clean on the fader.
Toyoto -
hello, my controller is corrupted (midi nano... corrupted) since a windows update, now the faders are going crazy by themselfs, i use ableton
Andrei Sebastian (callmetiti) - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 3,870
