Konica Minolta DiMAGE Z3 LCD Screen Replacement
  1. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Open the battery chamber: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Konica Minolta DiMAGE Z3 LCD Screen Replacement, Open the battery chamber: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the battery chamber door by sliding the door to the side of the camera to release the safety catch.
    • Lift the door up to open.
  2. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Insert the batteries: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the four batteries inside of the battery chamber door.
    • Make sure the positive and negative battery terminals are in the correct position.
  3. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove the viewfinder cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove the viewfinder cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a screwdriver to remove the four viewfinder cover screws.
  4. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove viewfinder screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2 small screws under the viewfinder.
  5. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove the screen cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screen cover by applying slight pressure at the top, then pulling the screen protector away from the camera.
    • Do not apply pressure to the surface of the LCD screen or it may be permanently damaged. If fingerprints are on the LCD monitor, gently wipe with a soft, clean, dry cloth.
  6. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove screws from the bottom panel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 6 screws on the bottom panel.
  7. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove screw from battery chamber: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 1 screw on the outer side of the battery chamber.
    • This will be under the rubber grip.
  8. Konica Minolta DiMAGE Z3 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 1 screw inside the battery chamber.
  9. Konica Minolta DiMAGE Z3 LCD Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the wrist strap away from the front of the camera to remove it.
    • Then carefully pull the back casing apart from the camera.
  10. Konica Minolta DiMAGE Z3 LCD Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3 screws that attach the LCD screen to the circuit board.
  11. Konica Minolta DiMAGE Z3 LCD Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the LCD screen from the circuit board.
    • There will be a ribbon cable and some wires attached to the LCD screen.
  12. Konica Minolta DiMAGE Z3 LCD Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to carefully pull the ribbon cable from the circuit board, not from the LCD screen.
    • Peel back tape on LCD screen to reveal where the wires are attached. Use tweezers to detach the wires from the LCD screen.
Hieu Ngo
crwdns2935283:003/22/17crwdne2935283:0
431 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S7-G4, Julie Spring 2017 crwdns2935289:0UMass Dartmouth, Team S7-G4, Julie Spring 2017crwdne2935289:0
UMASSD-JULIE-S17S7G4
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 828
