This guide provides instructions on how to replace a broken or cracked LCD screen on your Konica Minolta DiMAGE Z3.
Open the battery chamber door by sliding the door to the side of the camera to release the safety catch.
Lift the door up to open.
Insert the four batteries inside of the battery chamber door.
Make sure the positive and negative battery terminals are in the correct position.
Use a screwdriver to remove the four viewfinder cover screws.
Remove the 2 small screws under the viewfinder.
Remove the screen cover by applying slight pressure at the top, then pulling the screen protector away from the camera.
Remove 6 screws on the bottom panel.
Remove 1 screw on the outer side of the battery chamber.
Remove 1 screw inside the battery chamber.
Pull the wrist strap away from the front of the camera to remove it.
Then carefully pull the back casing apart from the camera.
Remove the 3 screws that attach the LCD screen to the circuit board.
Gently remove the LCD screen from the circuit board.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to carefully pull the ribbon cable from the circuit board, not from the LCD screen.
Peel back tape on LCD screen to reveal where the wires are attached. Use tweezers to detach the wires from the LCD screen.
