The “Free-Stand” button enables the stroller to fold into a freestanding, compact position. Sometimes the button can get stuck and requires simple internal repair. This guide will walk you through that process.
Unscrew the two, 27mm Phillips #2 screws from the back of the “Free-Stand” button case.
Remove the back cover of the case by lifting it straight up.
To access the spring, remove the red, "Free-Stand" button by lifting it straight up.
If the spring does not come out when you remove the "Free-Stand" button, lift the spring out of the case so it can be fixed or replaced.
