Kodak S100 EF Lens Replacement
  1. Kodak S100 EF Lens Replacement, Front Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Have the camera facing upwards and the flash closest to you.
    • Unscrew the two 6.2 mm Phillips screws on the top half of the camera.
  2. Kodak S100 EF Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the camera over to the other side-with flash farthest from you.
    • Unscrew top two 6.2mm Phillips screws on this side.
  3. Kodak S100 EF Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the camera so the bottom is facing up with the front-facing away.
    • Unscrew the 6.2mm Phillips screw on the top right.
    • The front cover is now unscrewed and should be lifted evenly and removed.
  4. Kodak S100 EF Lens Replacement, Lens: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 6.2mm Phillips screws on either side of the lens securing the metal plate.
  5. Kodak S100 EF Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull aside the plastic piece resting atop the metal lens plate in order to access the other screws.
  6. Kodak S100 EF Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove other screws, metal panel must be lifted up slightly to access.
    • Lift metal panel and insert screwdriver through holes in panel to reach screws underneath. Remove the two 6.2mm Phillips screws.
  7. Kodak S100 EF Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Look at the black plate on the right side of the lens that the metal plate is resting on.
    • Unscrew two 6.2mm Phillips screws on the black plate next to the lens.
    • At this point, all screws are removed and lens can should be carefully lifted and removed, including both plates and the plastic ring around the lens.
Michelle
crwdns2935283:004/04/11crwdne2935283:0
131 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 25-28, Garner Spring 2011 crwdns2935289:0Cal Poly, Team 25-28, Garner Spring 2011crwdne2935289:0
CPSU-GARNER-S11S25G28
crwdns2936753:030crwdne2936753:0 82
crwdns2942667:0crwdne2942667:0 2,401
