Kodak PixPro AZ251 Shutter Button Replacement
crwdns2869540:0crwdne2869540:0: 1.6K
12
69
1,557
crwdns2955950:0crwdne2955950:0: 3
crwdns2960004:03crwdne2960004:0.
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:030crwdne2931287:0
In this guide, you will learn how to repair and replace a loose or faulty shutter button on your Kodak PixPro AZ251.
    1. Kodak PixPro AZ251 Shutter Button Replacement, Batteries: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak PixPro AZ251 Shutter Button Replacement, Batteries: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide switch to open lock position.
    2. Kodak PixPro AZ251 Shutter Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak PixPro AZ251 Shutter Button Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Press down on the battery cover and slide outwards to open.
    3. Kodak PixPro AZ251 Shutter Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the batteries.
    1. Kodak PixPro AZ251 Shutter Button Replacement, Back Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kodak PixPro AZ251 Shutter Button Replacement, Back Cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kodak PixPro AZ251 Shutter Button Replacement, Back Cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove a total of four 5mm JIS #000 screws from around the camera:
      • Two screws from the right side.
      • Two screws from the left side.
    2. Kodak PixPro AZ251 Shutter Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the single 5mm Phillips #00 screw from the bottom.
    3. Kodak PixPro AZ251 Shutter Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak PixPro AZ251 Shutter Button Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Open the flash module.
      • Remove the two 6mm JIS #00 screws found inside of the flash housing.
    4. Kodak PixPro AZ251 Shutter Button Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kodak PixPro AZ251 Shutter Button Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kodak PixPro AZ251 Shutter Button Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a plastic opening tool to pry apart both halves of the camera.
      • Remove the back panel.
    1. Kodak PixPro AZ251 Shutter Button Replacement, LCD Screen: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak PixPro AZ251 Shutter Button Replacement, LCD Screen: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove these three JIS #000 screws from the control board:
      • 5mm screw.
      • 4mm screw.
      • 2mm screw.
    2. Kodak PixPro AZ251 Shutter Button Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the small metal switch plate to the side.
    3. Kodak PixPro AZ251 Shutter Button Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak PixPro AZ251 Shutter Button Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pry the LCD screen out of the metal housing plate with a plastic opening tool.
    4. Kodak PixPro AZ251 Shutter Button Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak PixPro AZ251 Shutter Button Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
      • Pull the orange cable out of the socket.
    1. Kodak PixPro AZ251 Shutter Button Replacement, Shutter Button: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak PixPro AZ251 Shutter Button Replacement, Shutter Button: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove one 4mm JIS #000 screw from the top of the camera.
    2. Kodak PixPro AZ251 Shutter Button Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak PixPro AZ251 Shutter Button Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using tweezers, disconnect the orange cable connection at the top of the motherboard.
    3. Kodak PixPro AZ251 Shutter Button Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak PixPro AZ251 Shutter Button Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the mode dial up and off of the camera.
      • Rotate carefully to avoid breaking the screw attaching the top side cover to the main body of the camera.
    4. Kodak PixPro AZ251 Shutter Button Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak PixPro AZ251 Shutter Button Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Turn camera upside down.
      • Remove the six 2mm JIS #000 screws from the metal base of the shutter button.
    5. Kodak PixPro AZ251 Shutter Button Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak PixPro AZ251 Shutter Button Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the metal base and ribbon cables.
    6. Kodak PixPro AZ251 Shutter Button Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • While holding the shutter button in place, remove the two 4mm JIS #000 screws from the base.
    7. Kodak PixPro AZ251 Shutter Button Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the plastic base of the shutter button using tweezers by pulling it straight upward.
    8. Kodak PixPro AZ251 Shutter Button Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the shutter button by pulling it out from the bottom side of the top cover.
Rachel Llewellyn
crwdns2935283:002/22/18crwdne2935283:0
509 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G1, Cagle Spring 2018 crwdns2935289:0USF Tampa, Team S1-G1, Cagle Spring 2018crwdne2935289:0
USFT-CAGLE-S18S1G1
crwdns2935297:084crwdne2935297:0
crwdns2936753:030crwdne2936753:0 69
crwdns2959996:0crwdne2959996:0 1,557
