Kodak PixPro AZ251 Mode Dial Replacement
  1. Kodak PixPro AZ251 Mode Dial Replacement, Batteries: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak PixPro AZ251 Mode Dial Replacement, Batteries: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide switch to open lock position.
  2. Kodak PixPro AZ251 Mode Dial Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak PixPro AZ251 Mode Dial Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press down on the battery cover and slide outwards to open.
  3. Kodak PixPro AZ251 Mode Dial Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the batteries.
  4. Kodak PixPro AZ251 Mode Dial Replacement, Back Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kodak PixPro AZ251 Mode Dial Replacement, Back Cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kodak PixPro AZ251 Mode Dial Replacement, Back Cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove a total of four 5mm JIS #000 screws from around the camera:
    • Two screws from the right side.
    • Two screws from the left side.
  5. Kodak PixPro AZ251 Mode Dial Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 5mm Phillips #00 screw from the bottom.
  6. Kodak PixPro AZ251 Mode Dial Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak PixPro AZ251 Mode Dial Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the flash module.
    • Remove the two 6mm JIS #00 screws found inside of the flash housing.
  7. Kodak PixPro AZ251 Mode Dial Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kodak PixPro AZ251 Mode Dial Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kodak PixPro AZ251 Mode Dial Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool to pry apart both halves of the camera.
    • Remove the back panel.
  8. Kodak PixPro AZ251 Mode Dial Replacement, LCD Screen: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak PixPro AZ251 Mode Dial Replacement, LCD Screen: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove these three JIS #000 screws from the control board:
    • 5mm screw.
    • 4mm screw.
    • 2mm screw.
  9. Kodak PixPro AZ251 Mode Dial Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the small metal switch plate to the side.
  10. Kodak PixPro AZ251 Mode Dial Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak PixPro AZ251 Mode Dial Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the LCD screen out of the metal housing plate with a plastic opening tool.
  11. Kodak PixPro AZ251 Mode Dial Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak PixPro AZ251 Mode Dial Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Pull the orange cable out of the socket.
  12. Kodak PixPro AZ251 Mode Dial Replacement, Mode Dial: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak PixPro AZ251 Mode Dial Replacement, Mode Dial: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove one 4-mm screw using a J000 screwdriver from the top of the camera, near the mode dial.
  13. Kodak PixPro AZ251 Mode Dial Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak PixPro AZ251 Mode Dial Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the tweezers, disconnect the orange cable connection at the top of the motherboard near the mode dial.
  14. Kodak PixPro AZ251 Mode Dial Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak PixPro AZ251 Mode Dial Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the top side cover up.
    • Rotate the top side cover to the right.
    • Rotate carefully to avoid breaking the screw attaching the top side cover to the main body of the camera.
  15. Kodak PixPro AZ251 Mode Dial Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak PixPro AZ251 Mode Dial Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the camera upside down.
    • Remove two 2mm JIS #000 screws from the metal base of the mode dial.
  16. Kodak PixPro AZ251 Mode Dial Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak PixPro AZ251 Mode Dial Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the metal base and remove the 4mm JIS #000 screw from the center of the mode dial.
  17. Kodak PixPro AZ251 Mode Dial Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak PixPro AZ251 Mode Dial Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The mode dial should now be loose and can be easily removed from the top side cover.
    • Turn the mode dial upside down to remove the metal part inside.
Rachel Llewellyn
crwdns2935283:002/22/18crwdne2935283:0
509 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G1, Cagle Spring 2018 crwdns2935289:0USF Tampa, Team S1-G1, Cagle Spring 2018crwdne2935289:0
USFT-CAGLE-S18S1G1
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 666
