Is the screen on your Kodak Easyshare Z981 camera malfunctioning, or not working at all? Need to replace the LCD screen entirely? LCD screens often need replacing when they contain visible cracks, exhibit display issues, or are generally unresponsive. Utilize this guide to save the trouble of a repair shop or new camera altogether, no special skills required.
Open the battery cover and remove batteries from the camera if any are inserted.
crwdns2935267:0crwdne2935267:0Phillips #00 Screwdriver$5.49
Use a 00 Phillips-Head screwdriver to remove screws:
Remove the 3 mm screws from the camera
Four (4) screws are in the bottom of the device
Four (4) screws are inside the battery cover
Start from a corner and gently remove the cover.
Use a Phillips #00 Screwdriver to remove the 4 mm screws from each side of the back cover of the camera.
Two (2) screws are located in the left side of the device
Two (2) screws are locatecd in the right side of the device
Insert the Plastic Opening Tool in to the crevices of back cover and gently apply pressure
Once the back cover is removed locate the four 3mm screws holding the screen and the metal brace to the circuit board
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Gently lift up the metal brace and use a pair if tweezers to disconnect the ribbon cable connecter
Use Tweezers to disconnect the ribbon cable connector.
Once disconnected remove the screen brace from the circuit board
