Kodak Easyshare Z981 Flash Button Replacement
  1. Kodak Easyshare Z981 Flash Button Replacement, Flash Button: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak Easyshare Z981 Flash Button Replacement, Flash Button: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the battery cover and remove the AA batteries from the camera if any are inserted.
  2. Kodak Easyshare Z981 Flash Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kodak Easyshare Z981 Flash Button Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kodak Easyshare Z981 Flash Button Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Phillips #00 Screwdriver
    $5.49
    • Remove screws using a 00 Phillips-Head screwdriver:
    • Eight (8) 3mm screws on the lower portion of the camera
    • Four (4) on the bottom of the camera
    • Four (4) on the inside of the battery cover
    • Four (4) 6mm screws on the sides of the camera (two on each side)
  3. Kodak Easyshare Z981 Flash Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Start from a corner and gently remove the bottom of the camera.
    • The cover will easily lift off, so not much pressure is required.
  4. Kodak Easyshare Z981 Flash Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak Easyshare Z981 Flash Button Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Plastic Opening Tool to remove the back of the camera
  5. Kodak Easyshare Z981 Flash Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kodak Easyshare Z981 Flash Button Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kodak Easyshare Z981 Flash Button Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four (4) 3mm screws attaching the LCD screen to the circuit board.
    • Use Tweezers to carefully detach the ribbon cable
    • Use extreme caution on this step, as the ribbon cable is very fragile and can rip very easily.
  6. Kodak Easyshare Z981 Flash Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kodak Easyshare Z981 Flash Button Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kodak Easyshare Z981 Flash Button Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the flash compartment and remove two (2) 3mm screws.
  7. Kodak Easyshare Z981 Flash Button Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak Easyshare Z981 Flash Button Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Plastic Opening Tool to carefully remove the top of the camera.
    • Use caution when removing the top of the camera
  8. Kodak Easyshare Z981 Flash Button Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kodak Easyshare Z981 Flash Button Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kodak Easyshare Z981 Flash Button Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove four (4) 3mm screws from the circuit board underneath the button set.
    • Gently move the circuit board aside.
    • Gently move aside the metal sheet.
  9. Kodak Easyshare Z981 Flash Button Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak Easyshare Z981 Flash Button Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use Tweezers to carefully remove the flash button.
    • The button should simply pop out when light pressure is applied.
Olivia Boyna
crwdns2935283:003/03/15crwdne2935283:0
509 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 13-6, Blackburne Winter 2015 crwdns2935289:0Sam Houston State, Team 13-6, Blackburne Winter 2015crwdne2935289:0
SHSU-BLACKBURNE-W15S13G6
crwdns2942667:0crwdne2942667:0 792
