This guide provides step-by-step instructions for removing and replacing the battery. There are two tools required and no safety precautions needed.
Turn off camera by firmly pressing the power button that is located on the top of the camera.
Position camera with the bottom facing up.
With your finger, slide the battery cover in the direction of the open arrow.
Gently push the battery down until a click is heard. Battery should release and be lifted out of slot.
Use a J00 screwdriver to remove the five exterior screws.
Use a plastic opening tool to pry off the back casing.
Completely remove the back casing from the device.
Using a plastic tool to remove the bottom.
