Use this guide to remove and install the front case.
Position the camera with the bottom facing up.
Slide the battery cover in the direction of the arrow with your finger gently.
Remove the batteries
Remove the seven 4.5mm screws with a Phillips #00 screwdriver.
2 on the left
2 on the right
3 on the bottom
Firmly grasp the back of the camera and pull the away the casing.
Keep the battery door open
Firmly grasp the front casing and pull away from the camera.
Preciso da tampa da bateria...
