Kodak EasyShare C713 Lens Replacement
    1. Kodak EasyShare C713 Lens Replacement, Batteries: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your finger tip to slide battery cover door away from the center of the camera.
      • The battery door should spring open.
      • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
    2. Kodak EasyShare C713 Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the old batteries.
    1. Kodak EasyShare C713 Lens Replacement, Outer Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kodak EasyShare C713 Lens Replacement, Outer Case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kodak EasyShare C713 Lens Replacement, Outer Case: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the seven screws from the outer case with a Phillips #00.
      • All screws are 4.45mm.
      • There are 2 screws on the port side.
      • There are 2 screws on starboard side.
      • There are 3 screws on the bottom.
    2. Kodak EasyShare C713 Lens Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kodak EasyShare C713 Lens Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kodak EasyShare C713 Lens Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Make sure the battery cap is "up".
      • Pull the outer case off with your hands.
    1. Kodak EasyShare C713 Lens Replacement, LCD: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The LCD screen is hinged at the bottom.
      • Put your thumb in the upper right corner of the LCD screen.
      • Pull the LCD screen out of its outer case with your thumb.
    2. Kodak EasyShare C713 Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the screw underneath LCD screen with the Phillips #00. The screw measures 4.1mm in length.
    3. Kodak EasyShare C713 Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak EasyShare C713 Lens Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Desolder the two points.
      • One on the port side.
      • One on the bottom.
    4. Kodak EasyShare C713 Lens Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • After desoldering the LCD casing, just use your fingers to carefully remove it.
    5. Kodak EasyShare C713 Lens Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip up the black tab on the bottom of the LCD screen with a fingertip.
    6. Kodak EasyShare C713 Lens Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the LCD ribbon cable from inside the black tab.
    1. Kodak EasyShare C713 Lens Replacement, Lens: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a fingertip, flip the black tab near the top of the camera.
      • Remove the ribbon connector from inside the black tab.
    2. Kodak EasyShare C713 Lens Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the remaining eight 4.1mm screws on the back with the Phillips #00 screwdriver.
    3. Kodak EasyShare C713 Lens Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Desolder the upper points.
      • There is a series of solder points in a rectangular area in the upper middle of the camera.
      • There is a large solder point in the upper right.
    4. Kodak EasyShare C713 Lens Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the camera over.
      • Remove the silver 2.2mm battery cap screw.
    5. Kodak EasyShare C713 Lens Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kodak EasyShare C713 Lens Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pry the capacitor out of its holder on the bottom of the camera with your fingers.
    6. Kodak EasyShare C713 Lens Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kodak EasyShare C713 Lens Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kodak EasyShare C713 Lens Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the lens assembly with your fingers.
      • You may need to wiggle it back and forth until it comes loose.
      • Do not touch the marked areas. This will cause the camera to take blurry pictures.
Taggart Ashby
crwdns2935283:004/15/10crwdne2935283:0
360 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 26-19, Regan Spring 2010 crwdns2935289:0Cal Poly, Team 26-19, Regan Spring 2010crwdne2935289:0
CPSU-REGAN-S10S26G19
why didn't you mention to discharge the capacitor, its stored charge is pretty high & dangerous
richard - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 49
crwdns2942667:0crwdne2942667:0 7,874
