Screen replacement refers to the process of removing a damaged or malfunctioning display screen from a device and replacing it with a new one. This can be necessary for various electronic devices such as smartphones, tablets, laptops, and even some types of gaming consoles. The need for screen replacement usually arises when the original screen is cracked, scratched, malfunctioning, or otherwise compromised. This guide will show you how to replace the screen for a Kocaso M750B tablet.
Pry the edges of the tablet apart using an iFixit opening tool.
Remove three 1.2 mm screws from the motherboard using a Phillips #000 screwdriver.
Desolder the connections to the motherboard and the display.
Remove the display by loosening the tabs surrounding it.
You now have independent access to the tablet's screen.
