This guide will help you gain access to the camera of the Kocaso M750B. Before considering repair make sure to visit the Kocaso M750B Troubleshooting page to make sure a replacement is necessary. Also make sure to work carefully because there are many parts that when damaged, are dangerous and costly.
Pry the edges of the tablet apart using an iFixit opening tool.
Pry the battery up using the flat end of a spudger.
Remove the adhesive under the battery and carefully lift it up.
Detach the ribbon cable connecting the camera to the motherboard.
Gently pull on the black strip away from the motherboard. Once you hear a slight click, the ribbon cable should now come loose.
You can now remove the camera.
