Kobold VK150 Wiring Harness Replacement
  1. Kobold VK150 Wiring Harness Replacement, Remove screws from housing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kobold VK150 Wiring Harness Replacement, Remove screws from housing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a TX10 screwdriver
    • Remove the housing screws on the rear of the device.
    • 6 long screws
    • 3 short screws
  2. Kobold VK150 Wiring Harness Replacement, Remove housing cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the device with the white lid facing up.
    • Start to carefully lift the lid at the front of the suction nozzle. Slowly work your way up to the stem.
    • At the top of the stem, a small plastic part holds in the gray casing of the suction cup!
  3. Kobold VK150 Wiring Harness Replacement, Separate parts: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now you can lift the flap of the vacuum cleaner bag. This was only held by the white lid.
  4. Kobold VK150 Wiring Harness Replacement, Remove the plug: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kobold VK150 Wiring Harness Replacement, Remove the plug: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the power supply connector by pressing the unlocking lever.
    • Unplug the motherboard connector.
    • Put the cable aside
  5. Kobold VK150 Wiring Harness Replacement, Remove the wiring harness: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kobold VK150 Wiring Harness Replacement, Remove the wiring harness: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kobold VK150 Wiring Harness Replacement, Remove the wiring harness: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unlock and loosen the rotary switch plug.
    • Disconnect the white air hose from the intake manifold.
    • Release 2 plastic clips
    • Remove the wiring harness with the plastic holder.
Follow the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934883:0oldturkey03crwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Lukas Fritz
crwdns2935283:012/25/19crwdne2935283:0
362 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 110
crwdns2942667:0crwdne2942667:0 2,714
