Kobo Mini Disassembly
  1. Kobo Mini Disassembly, Kobo Mini Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kobo Mini Disassembly, Kobo Mini Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull on the corner to remove the cover.
  2. Kobo Mini Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six screws.
    • Remove the back of the device.
  3. Kobo Mini Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws from the mother board.
    • Remove the screen connector and the battery connector.
    • Remove the micro SD card.
    • Remove the motherboard from the chassis.
  4. Kobo Mini Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kobo Mini Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four screws from the screen frame.
    • Remove the screen
  5. Kobo Mini Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • And we finally finished.
Gabriel Bédard
crwdns2935283:006/07/18crwdne2935283:0
303 crwdns2915208:0crwdne2915208:0
crwdns2947412:09crwdne2947412:0
Just a quick note, I noticed that the SD card in the teardown is a 4gb one. The Kobo Mini has only 2gb of storage. There's just under 2gb of unpartitioned space. You can use a partition manager to extend out the last partition to fill the card, and get close to 4gb of space.
There's a guide over on Mobile Read: https://www.mobileread.com/forums/showth...
Stephanie Raccoon - crwdns2934203:0crwdne2934203:0
Thanks for the teardown! See https://www.mobileread.com/forums/showth... and https://wiki.mobileread.com/wiki/Kobo_Mi... for more disassembly advice and information about the components used.
I would be concerned about the reliability of the 4GB micro SD cards when extended to use the full unpartitioned space. While I could imagine a situation where 4GB cards were used due to unavailability of 2GB cards, there doesn’t seem to be a good reason to only format them to 2GB unless they were only guaranteed to reliably hold 2GB of data. In other words, I wonder if they were originally 4GB cards that failed some QA test and were only rated for use as 2GB capacity cards.
David Boddie - crwdns2934203:0crwdne2934203:0
How do you remove the battery connector? Simply pull? Remove the black little things on the sides in some way?
jasonhayden - crwdns2934203:0crwdne2934203:0
Yes you just need to pull it from the motherboard
Gabriel Bédard -
Hi, my kobo mini on/off switch is somehow defect. Is it possible to get a replacement for the old one or is it possible to repair it? Has anyone the same problem here?
Kind regards
Ariane
Ariane Zimmer - crwdns2934203:0crwdne2934203:0
Hi there, I had an issue detaching the screen case from the screen chassis at Step 4. Mine appeared to be glued together. I was afraid to pry them apart or apply more pressure. Did you have the same issue please? Thanks!
nerm - crwdns2934203:0crwdne2934203:0
Hi Nerm (maybe not for you given the time since your post, but I was hunting for the same info this mornin’ hope this will help someone)
Yes the plastic front chassis has a strip of adhesive just on the inside edge of the screen. I found a little gentle heat and flexing of the chassis in a corner should give you some room to get a plec or really fine spudger and just gently run down the edges from the front.
latro -
Hi, on mine the screen was glued. No way I could remove it without breaking it. Well it was already broken and I wanted to change it, but if it's the same on all kobo mini I will never be able to use a spare screen from a disused apparel :/
Susan - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 95
crwdns2942667:0crwdne2942667:0 5,611
