Kobo Glo E-reader USB Port Replacement
  1. Kobo Glo E-reader USB Port Replacement, Remove the back panel and the screws.: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kobo Glo E-reader USB Port Replacement, Remove the back panel and the screws.: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    FixMat
    $36.95
    • Make sure to store the screws somewhere you won't loose them, like on your FixMat.
  2. Kobo Glo E-reader USB Port Replacement, Disconnect the ribbon cable: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • All you have to do is lift the black locking arm that is keeping the ribbon cable in place. See picture.
  3. Kobo Glo E-reader USB Port Replacement, Remove the motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the motherboard from your e-reader.
  4. Kobo Glo E-reader USB Port Replacement, Check the voltage on all six motherboard pins: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check the voltage of all six pins: if a pin shows no voltage level this probably means the pin is loose.
    Om welke 6 pinnen gaat dit en hoe test ik de spanning dan precies?
    Erwin van Walsem - crwdns2934203:0crwdne2934203:0
  5. Kobo Glo E-reader USB Port Replacement, Resolder the disconnected pin(s): crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use as much flux as possible (i.e. with the use of a flux marker).
    • A magnifying camera makes the job a lot easier.
    • Make sure that the pins are not touching each other.
  6. Kobo Glo E-reader USB Port Replacement, Put back the motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kobo Glo E-reader USB Port Replacement, Put back the motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully reassemble the parts.
  7. Kobo Glo E-reader USB Port Replacement, Final check: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure that the e-reader functions properly before completely reassembling and closing it.
    Waar is de usb poort te bestellen. Ik merk dat er veel verschillende soorten zijn. Ik heb bij Conrad een verkeerde besteld.
    Remco Van den Beld - crwdns2934203:0crwdne2934203:0
crwdns2934873:0crwdne2934873:0
nl en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Laura Ahsmann
crwdns2935283:010/02/19crwdne2935283:0
274 crwdns2915208:0crwdne2915208:0
My on/off button stopped working. The kobo won't start.... Thank you!
E K - crwdns2934203:0crwdne2934203:0
I needed to see how the USB plug was aligned on the motherboard and your guide showed me exactly this. Since I am not able to solder I will ask someone else to do the job, but at least I know I tried my best. Thank you.
VooBee - crwdns2934203:0crwdne2934203:0
Where did you buy the replacement part from?
Techie -
Hello guys, two of the pins on my reader are broken and I can't find the exact micro usb b model to buy the replacement.
Do you recommend a website to get it from?
Thanks a lot for your help
Edu Insua - crwdns2934203:0crwdne2934203:0
There was one on Ebay
Test taaaa -
There was one on eBay, there are ways to get Kobo to replace but they need receipt for 12 months.
They will offer coupons to buy newer unit.
WHY TF did they make the charge port so weak, so we can break over time and buy new device. F-that. Anyways that's what we did.
Still looking for affordable USB port replacement, some used units cost as much as the replacement parts.
Test taaaa - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 49
crwdns2936753:030crwdne2936753:0 174
crwdns2942667:0crwdne2942667:0 7,950
