Kobo Glo E-reader USB Port Replacement
  1. Kobo Glo E-reader USB Port Replacement, Remove the back panel and the screws.: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kobo Glo E-reader USB Port Replacement, Remove the back panel and the screws.: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    FixMat
    $31.41
    • Make sure to store the screws somewhere you won't loose them, like on your FixMat.
  2. Kobo Glo E-reader USB Port Replacement, Disconnect the ribbon cable: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • All you have to do is lift the black locking arm that is keeping the ribbon cable in place. See picture.
  3. Kobo Glo E-reader USB Port Replacement, Remove the motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the motherboard from your e-reader.
  4. Kobo Glo E-reader USB Port Replacement, Check the voltage on all six motherboard pins: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check the voltage of all six pins: if a pin shows no voltage level this probably means the pin is loose.
  5. Kobo Glo E-reader USB Port Replacement, Resolder the disconnected pin(s): crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use as much flux as possible (i.e. with the use of a flux marker).
    • A magnifying camera makes the job a lot easier.
    • Make sure that the pins are not touching each other.
  6. Kobo Glo E-reader USB Port Replacement, Put back the motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kobo Glo E-reader USB Port Replacement, Put back the motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully reassemble the parts.
  7. Kobo Glo E-reader USB Port Replacement, Final check: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure that the e-reader functions properly before completely reassembling and closing it.
crwdns2934873:0crwdne2934873:0
nl en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Laura Ahsmann
crwdns2935283:010/02/19crwdne2935283:0
274 crwdns2915208:0crwdne2915208:0
My on/off button stopped working. The kobo won't start.... Thank you!
E K - crwdns2934203:0crwdne2934203:0
I needed to see how the USB plug was aligned on the motherboard and your guide showed me exactly this. Since I am not able to solder I will ask someone else to do the job, but at least I know I tried my best. Thank you.
VooBee - crwdns2934203:0crwdne2934203:0
Where did you buy the replacement part from?
Techie -
Hello guys, two of the pins on my reader are broken and I can't find the exact micro usb b model to buy the replacement.
Do you recommend a website to get it from?
Thanks a lot for your help
Edu Insua - crwdns2934203:0crwdne2934203:0
There was one on Ebay
Test taaaa -
crwdns2936753:07crwdne2936753:0 52
crwdns2936753:030crwdne2936753:0 196
crwdns2942667:0crwdne2942667:0 9,248
