Knog Blinder R70 battery Replacement
  1. Knog Blinder R70 battery Replacement, battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is the bottom of the circuit board that you will see, the battery wires are the black and red: you need to detach them from teh circuit board with a soldering gun, ready to solder in the new battery with its connectin wires.
    very interesting attempt....please do update how you went with this....
    my R70 is taking soooooo long to charge now, so I'm very much interesting in attempting this battery change...
    Agreed....Knog does appear to discourage any sort of attempt at repairs....rather dismissive on the emails when trying to get advice re how to do so...
    aboydie2003 - crwdns2934203:0crwdne2934203:0
    I managed to do the change fine based on the above. I did seal the light with black insulating tape around it though since the seals seem single use.
    Andy Pleming - crwdns2934203:0crwdne2934203:0
    good news, congrats! so the option 2 battery fits ok? 🤔
    DJ Panther - crwdns2934203:0crwdne2934203:0
    UPDATE: 801350 fits
    3) I fitted 801350 OK, it was difficult to get the slim water proof rubber seal around the light so I added electrical tape around to ensure water proof.
    G'day Andy...i managed to get hold of this battery...however, it is an incredibly tight fit!! the issue is that it is so long that it pushes against the plastic tabs near the switch...I'm not that comfortable pushing the battery to make it fit...I did so only very gently, and it does seem to finally get there.
    Did you have similar issues, and if so how did you solve? I'm thinking of melting a bit of the plastic near the CREE holder on the other end just to make a tiny bit more space...this should work, but I think it's worth mentioning to anyone else attempting this fix that this particular battery only JUST fits, and it would be better to use a battery that is, let's say, a few mm less long...
    Update! OK, I did have to melt a tiny bit of the CREE holder to make a bit more space because I wasn't that comfortable squeezing the battery in...it may not have needed it, but I guess just being cautious. Be careful with the two side USB charging wires because they go around the battery's sides (if not, it's also hard to make the battery fit).
    To ensure the sides stay together, I've glued both top and bottom ends...once dry, I'll apply a thin layer of silicone to get a seal. OK, when the battery goes in a few years, it may be a minor task to get it open again, but shouldn't be too much of an issue.
Andy Pleming
crwdns2935283:004/05/23crwdne2935283:0
169 crwdns2915208:0crwdne2915208:0
UPDATE: 801350 fits
crwdns2942667:0crwdne2942667:0 421
