KitchenAid Professional 600 Worm Gear Replacement
  1. KitchenAid Professional 600 Worm Gear Replacement, Top Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
    • Remove the silver band.
    Maybe start with unplugging it ?
    Ryan F - crwdns2934203:0crwdne2934203:0
  2. KitchenAid Professional 600 Worm Gear Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four Phillips #2 screws located around the mixer where the band was removed.
    • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
  3. KitchenAid Professional 600 Worm Gear Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top of the mixer to reveal the inner parts.
    • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
  4. KitchenAid Professional 600 Worm Gear Replacement, Gear Housing Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 Phillips #2 screws connecting the black housing cover to the device.
    • Only one of the screws is seen in the picture. The other three are also located around the black housing cover.
  5. KitchenAid Professional 600 Worm Gear Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take off the black housing cover.
  6. KitchenAid Professional 600 Worm Gear Replacement, Worm Gear: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Worm Gear.
    • The Worm Gear is the part that is lying horizontal.
    • Remember to apply food safe grease onto your new replacement part before assembling the device back together.
    Before replacing part, make sure you remove all the old grease (the black gunk). It could contain metal shards that will quickly wear down gears. I used a 50% alcohol and a lot of rags and cotton swabs (Q-Tips®). Make sure everything is dry before placing new food-grade grease.
    mommarosie - crwdns2934203:0crwdne2934203:0
    How do I know the code of this part?
    Thuy Truong - crwdns2934203:0crwdne2934203:0
    Kirtchen Aid Store Part Nr. KitchenAid W10112253 481201230741
    VauWeh -
    This part probably fits, but you have to check carefully.
    VauWeh -
    The parts nr is not correct! Does anybody have the correct nr?
    Dr. Crimper -
    Is there a part number for the two metal stand off guide things on the worm gear?
    Kunwardip Mooker - crwdns2934203:0crwdne2934203:0
crwdns2935229:09crwdne2935229:0
Luke
crwdns2935283:004/11/16crwdne2935283:0
1,380 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 25-4, Maness Spring 2016 crwdns2935289:0Cal Poly, Team 25-4, Maness Spring 2016crwdne2935289:0
CPSU-MANESS-S16S25G4
crwdns2935297:018crwdne2935297:0
No tiene ningún tornillo a los lado eso es mentira
Guillermo Perez - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 108
crwdns2942667:0crwdne2942667:0 20,801
