KitchenAid Mixer Motor Repair
  1. KitchenAid Mixer Motor Repair, Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This Is the Most Common KitchenAid Mixer Malfunction—And How to Fix It
  2. KitchenAid Mixer Motor Repair: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 KitchenAid Mixer Motor Repair: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the lid there is one screw at the back holding the band onto the mixer, and four screws holding the lid on.
  3. KitchenAid Mixer Motor Repair: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 KitchenAid Mixer Motor Repair: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are four screws holding the motor in place remove them and lift the motor out. Remember to disconnect the wiring connector before you remove the mixer motor from the body.
  4. KitchenAid Mixer Motor Repair: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 KitchenAid Mixer Motor Repair: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Install the new motor W10247536 number #2 and test it after you reinstall all the screws holding it down. Remember to hook back up the electrical wires before testing the KitchenAid Pro Series Stand Mixer Motor.
Adam Basaraba
crwdns2935283:002/04/21crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
This is useless. It doesn't even show the motor being removed. You'd have to at least open the gearbox as well.
Jeff B - crwdns2934203:0crwdne2934203:0
I'd recommend opening up the transmission housing, but actually it will slide in and out without opening it up. But its worth it just to grease up and its only 4 screws.
Cyrus Fox -
Careful when you remove the plugs on the power board, I had one where the solder joints broke from the board and the connector was still attached but no longer electrically connected. Try to get a spudger or anything to help pry connectors off, when pulling, pull straight out do not wiggle connectors.
I was able to fix the board by resoldering large globs on the back in to get it reconnect to the traces... Its working for now and if I had to I cut scrap off more of the PCB to reveal fresh traces to connect to but better to not have to do this.
Replacing the motor fixed the burning electric smell coming from the old one.
Cyrus Fox - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 50
crwdns2936753:030crwdne2936753:0 260
crwdns2942667:0crwdne2942667:0 12,599
