The KitchenAid #KUDS01DJSS dishwasher's electronic control board can be replaced using this guide. You can verify your dishwasher's model by checking inside the door.
The control board controls all of the dishwasher's functions, such as filling, washing, drying, and draining. Symptoms that match your issue can be diagnosed by viewing these Dishwasher Repairs. During the time it takes to replace the dishwasher control board, remind your family not to run the dishwasher for about 30 minutes.
Before replacing the electronic control board, make sure the power/electricity is off. Disconnect the dishwasher from any external power source before starting the process and turn off the dishwasher completely.
Unplug the dishwasher or shut off the house circuit breaker for the dishwasher.
Remove the four screws from each side of the dishwasher door (eight screws total).
Removing the three screws from each side of the dishwasher (six screws total).
Support the outer door panel with one hand as you remove the final two screws at the top of the dishwasher door.
Use your hands to pull off the outer door panel with the control panel.
Disconnect the two white outer wires by pulling them out.
Remove the white rectangular connector that has six colored wires connected to it.
Use one hand to hold the control panel while detaching the black connector.
Detach the white and gray ribbon cable attached to the black connector.
Use your hands to pull the electronic control board out the mounting slots.
Push the new electronic control board into the mounting slots.
Slide it to the right to engage the locking tab until you hear a click.
Reconnect the black connector wires to the new electronic control board.
Reconnect the white rectangular connector with six wires to the new electronic control board.
Reconnect the two white outer connector wires to the new electronic control board.
Reinstall the outer door panel and control panel on the inner door panel and reattach the user interface control wire harness.
Reinstall the sixteen mounting screws.
Connect the dishwasher and reset the circuit breaker for your house to restore electricity.
Excellent illustration!!!
عمل فنى رائع وجميل وبدقة متناهية
عمل فنى جميل ورائع وبدقة متناهية
Excellent how to! However the part attached to purchase doesn’t look like the original control board. Help!
